Old 05-21-2007, 05:12 PM   #1
Lyn Smith
Liked 967 Times in 194 Posts
Default Qjet problem!!!!!!!!!!!!
Got a hesitation bobble at the top of first gear. I still have the power valve and rods in the carb. Would taking them out help the problem? What are the pros and cons of taking it out be? Thanks Lyn
Lyn Smith
Old 05-21-2007, 09:50 PM   #2
alan junkerman
Default
first of all, what kind and size fuel pump and size fuel line are u running?
alan junkerman is offline   Reply With Quote
Old 05-22-2007, 10:17 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
Default
Check the air flap on the secondary. it could be open to far causing a lean pop. should measure 1.380 from the choke horn. also close in around the secondary metering rod holes in the gasket with electrical tape. I also run a 90 degree sparlk plug boot on the main vent tube to stop any splash. Check to make sure that your fuel flow at the carb is a gallon in about 20 seconds.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
