Liked 419 Times in 85 Posts
Is there a swap to use a spindle off a car that can be used to get a decent front brake set up for a 1965 Chevrolet Biscayne? It appears there is no good aftermarket brakes for the car.
thanks in advance for the help |
Liked 886 Times in 238 Posts
Paul, Wilwood does make several disc kits for the Impala, although they are all vented rotor style . I put a set of their Dynalite Pro 11" brakes on a friends '67 Biscayne . .total bolt on .
The only down side for racing is the slightly heavier rotor which is .13/16" wide instead of 3/8" might be a good thing on a 3800 pound car having the vented rotors
Liked 75 Times in 7 Posts
Paul I bought a bolt on lightweight front brake kit from aerospace 10 years ago for my 67 . If I remember correctly it was the same as an early sixties corvette . it fit the drum brake front spindles perfectly.
Liked 14 Times in 7 Posts
Hi Paul. I swapped in a complete ‘70 Impala front disc brake setup with the single piston calliper on my ‘65 Impala for everyday street driving years ago. It’s a direct bolt in. It made a huge difference in braking control over the darty drum brakes.
If you are looking for a light weight race set up, Mark Williams should be able to help you. The spindles are essentially the same as a C 2 and C 3 Corvette. ‘68 and earlier use the smaller drum brake bearings, so you can use your ‘65 spindles. They don’t list the early, small bearing Corvette brakes in their catalog but they have everything to make up a kit. The Corvette parts will physically fit, but confirm with them that their brakes will work for the weight and application you have planned. The MW kit may also require machining the anchor bolt boss. They can do that for you.
Will Zoric 68 Corvette SS/A Getting closer 62 Bel Air 409/4spd bracket car Last edited by Super Eh; 07-15-2025 at 03:25 AM. Reason: ? > ‘ |
Liked 335 Times in 182 Posts
Use your original 65 Chevy spindle and get 70 Chevelle Stock GM rotors and bearings, grease seal ,stock castle nut --- washer/cotter pin and 70 Camaro Stock GM calipers left and right and stock GM pads will work --Stock GM camaro brake hoses proper length of course --you will have to get the correct lug bolts of course-you will have to get the caliper mounting brackets on line several companies have them--- gives you stock ride height not a lowered spindle--you want to do anything else thats on you like lightened stuff etc. ---My grandson did this on a 66 Impala so it should work on a 65-- not sure where he got the brackets from but will ask him--- ONLY 15 inch or larger wheels will work NO 14 inch wheel will fit----FED 387
Paul-- he bought the mounting bracket kit---includes all brackets, nuts, bolts spacers etc are included in the kit from CPP--Classic Performance Products phone #800-854-1280 Huntington Beach California ====kit # 6568DBK about $100
Thanks for all the help texts and phone calls. With your help I have gotten the parts I need coming to keep another modern junior stocker alive.
