Old 12-22-2024, 02:26 PM   #1
Dave Toce
Default Advanced Clutches Single 9" Billet SBC BBC Rob Youngblood
Single 9" Advanced Clutches i.e. Rob Youngblood, Billet clutch with throw out bearing. 153 tooth flywheel for SBC or BBC. The entire unit weighs 24 lbs. Also comes with the special micrometer used to set the ring height. This unit will need to be freshened as the disc is wore out. Very adjustable clutch used behind a 395 ci sb 812 hp 3250 lb car. I'm drastically changing combinations and can't use this anymore. Photos to large to post here refer to RJ ad. Thank you
https://www.racingjunk.com/clutches/...61&np_offset=0
SOLD
Dave Toce is offline   Reply With Quote
Search this Thread:
Advanced Search
