Liked 147 Times in 38 Posts
Would like to find a used BowTie or Dart SHP block that would clean up at .040 over 4? bore?fairly local to Lexington, KY. Wouldn?t mind driving a few hours. This is for a bracket engine I have that started leaking water from a repaired sleeve in a stk block. Planning to use my rotating assembly, this is reason I need .040 over. May be a reach but wanted to check. Call or text 502-316-4667 Kevin Wells
Liked 694 Times in 206 Posts
Kevin if you get the Dart SHP block I have oil restrictors for the block if you think you need them. You can PM me..
