Liked 30 Times in 14 Posts
Looking at a natural P/SA car and adding weight down to Q/SA with a 307. Everything I?m reading about the 307 is bad though. Not sure I want to put the money into that motor or not
Liked 239 Times in 114 Posts
If you are talking about a 307 Oldsmobile roller cam engine, that is a pretty good engine, with lots of potential. There is plenty of parts available, Olds used to give away lots of parts, good in Stock and Super Stock.
The Chevy small block
Liked 1,952 Times in 439 Posts
You need to reach out to Billy Nees.
Alan Roehrich 212A G/S |
Liked 166 Times in 46 Posts
That tiny 2 barrel carb kills it.
#6 | |
Liked 419 Times in 85 Posts
If we are talking about a 307 Chevrolet, It looks tougher but has been defactored quite a bit. Last edited by Paul Wong; 05-29-2024 at 11:18 AM. |
#7 | |
Hot rodders and street rodders think the 305 4 bbl. in the worst engine ever made LOL Also depends if you have the right car, and where you race. The 71-72 Nova is de-factored down to 165...It's a Q,R,T car Can't be all that bad, if you are a hands on guy. If not , probably not the combo for you.
#8 | |
Liked 432 Times in 214 Posts
Just starting the hard climb here of just ordering the parts to take an old EFI 80's Era car from the dark ages of locked up ECM/PM (pretty much non-tunable), into the 2024 higher tech, tunable Era, and get it right without taking it out to an expert to pay a fortune to wire it all up takes a ton of money and time, but the learning is also fun if you have the time to learn. And I would not have it any other way right now. The mission, to the means to the end, is half the fun of getting there! My plan though, includes a (plan B), way to within a few hours (should a failure happen without a slew of spare electronics), to be able to rewire it right back to where it is right now, at the track if necessary & overnight. With all the above opinions running from a great combo, to a lousy combo, sometimes success is in the hands of the holder like Paul and Yac said, knowledge and hands on, blaze your own trail, and find a way to succeed. As late as March I thought I had the worst combo available under the sun, then I embraced the slow fully, after experimenting a bunch, and just found out what improvements it really needs, and though a bit expensive these days, with a bunch of hard work, some of the expense can be minimixed. Give me a do over, and the old days and I would choose a carbed combo any day, and solve my current issues with a simple expertly put together jetting kit, and a 1 day track rental. But, that just isn't what I chose to compete with. Whatever you choose it is a challenge, just embrace the challenge, as there are no magic bullets.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#9 | |
Liked 520 Times in 176 Posts
At 165 HP that could be do-able. Problem today is going to be able to find engine parts like heads, blocks and intakes. That engine has small intake runners and intake valve. The venturi size isn't that far off for the engine that size. The later 305 Two barrel runs pretty well when someone that has an understanding of the combination goes to work on it. In the past I've found the 307 blocks to be pretty thick cylinder walls, and better late model oiling system. I used those blocks in 287 and 292 SB Modified engines a long time ago. Since it's not factored to death that might be a good combo to work with and mature. Just my humble opinion. Respectfully, Henry Kunz 1534 H/SA Last edited by Henrys Toy; 05-29-2024 at 11:22 AM. |
Liked 7,925 Times in 1,760 Posts
Well, I guess it all depends on what you're looking for. 1.30 under ain't gonna happen. Not unless NHRA decides to give it a "gift" kinda' like the 302 FFFFords got.
It's a good, dependable combo and it's consistant. If you were looking for something to Bracket race and run some Combo races and an occasional Div. race, it will be fine. I've gone .80+ under with mine in real good air. Oh, that's with a PG. A good metric would definitely step it up.
