Liked 598 Times in 164 Posts
New in package MSD 2 step module $75
Used MSD low RPM chip set 3000-7000 rpm in holder pack $150 Used MSD high RPM chip Set 7000-11,5000 RPM in holder $150 New Meziere BBC water pump with reservoir built in $400 Used MSD degree chips from 2-10 degrees in Tavia Holder $60 Racepak Card cartridge Reader and 2 cartridges $300 New Racepak vnet air/fuel controller single channel $425 New Biondo Pro Bandit shifter Electric Solenoid $135 New C&R chiller check valve for radiator hose $250 Holley Alcohol Jet Kit $100 Digital Delay Mega 450 delay box used for display only $350 Enderle Alcohol Mechanical Fuel Pump with regulator, fuel log, and lines $750 Stinett Dominator from S/C dragster set up to work with throttle stop. $1000 Under carb throttle stop, scoop mount and everything $350 8, 1.6 Harland Sharp Roller Rocker Arms SBC $150 Guide plates, studs, poly locks and stud girdle for SBC $175 Turbo Start battery Charger $225 Rich 631-461-6761 Last edited by rboyle; 01-12-2024 at 09:16 PM. |
