Old 12-03-2023, 09:09 PM   #1
Meaney124
Default Gear & Tire question
I have an 70 nova bracket car, looks like it was built around the 90s or so. The car is on 33x10.5 Hoosier slicks, 5:13s in the rear. I’m hitting trap around 63-6500. How would going down to 29s affect my car? Car is running around 7.4-7.5.
Car specs:
12 bolt
Strange axles
5.13 gears
Th400 reverse manual valvebody no brake
60 over 350
Dome top pistons
H beam rods
Solid lift cam
Holley alum heads
Quick fuel 750
Meaney124 is offline   Reply With Quote
Old 12-04-2023, 07:46 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Gear & Tire question
1/8th mile?
cam specs?
converter size, flash rpm and fall back rpm
stock suspension?
footbrake?
Old 12-04-2023, 08:02 PM   #3
Meaney124
@1320racer 1/8th mile unsure of cam specs haven’t torn apart to get numbers or anything, ladder bar, and footbrake is about all the info I can give you lol
Old 12-04-2023, 08:05 PM   #4
Meaney124
Originally Posted by 1320racer View Post
1/8th mile?
cam specs?
stock suspension?
footbrake?
check my other reply, really wondering how it will affect et and mph in case I decide to do any local index classes
Old 12-04-2023, 08:11 PM   #5
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
Summit has a gear ratio calculator on their site. Plug in the info it should get you close
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 12-05-2023, 10:54 PM   #6
goinbroke2
Liked 405 Times in 158 Posts
So, you must be trapping about 118mph at 6500?
33 to 29 inch tire jumps you from 6475rpm to 7367rpm. (approx)
http://wallaceracing.com/calc-gear-tire-rpm-mph.php
Old 12-06-2023, 07:45 AM   #7
Keith 944
Keith 944's Avatar
A 7.50 car going 118????
Don’t know if he mentioned it is 1/8 mile. Lol.
I do believe some of these calculators have 1/8 mile data
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
