Old 12-01-2023, 09:38 PM   #1
goinbroke2
Liked 405 Times in 158 Posts
Default U/SA 302 ffffford build
I was told I should start documenting the build. Probably a good idea as everyone has seen tons of chev and mopar builds.
So, I have a 83mustang GT that I bought in 84. Street and bracket raced it until 1997. First kid/new house/etc, etc.
Started building it as a 460 bracket car, got 68 429 close chambered heads etc....then talked to guys racing 460 fox bodies and was told a 351w is a better combo. Ok, got a 351W a set of gt40 heads and.....I want a stocker, always wanted a stocker....I have a roller 5.0 and the GT40 heads, I'll build a crate motor! (we can run them here in the maritimes) Then someone mentioned if I'm building a stocker, might as well build a real stocker. But, a 83 mustang SUCKS!! Bad heads/cam/etc. Change it to a 85? No, still bad heads, but roller cam. Nope too much to make it competitive. 302 2bbl has an awesome factor, maybe I'll do that. 302 2bbl stuff is throw away right? Should be cheap build, right?
No.
Bought a 79 mustang for the nose/hood/heads/front bumper. Had to buy a 2bbl intake with the right numbers. I swapped the nose/hood over and come to the conclusion that I should of got a western car and started with that instead of converting a bracket car back to a stocker.
Anyway, waiting for a return call from Deano carbs for the carb, trying to get a cam but logistics is getting foolish. (comp doesn't sell to Canada now) Haven't called about a converter yet but further down the road.
Old 12-01-2023, 09:41 PM   #2
goinbroke2
Default Re: U/SA 302 ffffford build
Here is some work I did on it while it was still going to be a bracket car.
Old 12-01-2023, 09:48 PM   #3
goinbroke2
As you can see, it ain't pretty! But the video on the 9" got me thinking, is there specific locations to add the ears? As in, factory 8.8 is 4" from center of axle to center of upper control arm bushing. Is this ever checked? Since it never came with a 9", it needs ears welded on, but does NHRA check that it is at factory distance? Obviously moving the ear up or down would change the instant center which is an "advantage". Not too concerned as it's the same as factory but I was just curious since you can't "weld" on suspension stuff.
(or did I miss a perfect opportunity to shut the %$%^ up??) LOL!
Old 12-01-2023, 10:29 PM   #4
goinbroke2
I have some pics but this site only allows 1200x800 which is half a fender with my camera. Not computer savy enough to figure it out right now, lol.
In other news...I bought a milling machine to cut down the rocker arm pedestal boss and to resurface the heads. I figure I have everything to install valve guides, cut 5 angle valve jobs, might as well get a milling machine too! (wife is pissed I'm spending so much just before Christmas but, I "need" it, lol) Deck the block? All kinds of idea's now!
Spending a lot of money to go really, really slow! LOL!!!!
Old 12-01-2023, 10:30 PM   #5
Liked 5,139 Times in 1,962 Posts
First reply..Surely not the last LOL
With the style of uppers you have, you just about have to have the right spacing on the housing. You did miss an opportunity to make or buy adjustable heim end uppers.
Yes, you can raise the uppers on the housing. Moser's 12 bolt Chevelle rears are built that way.
I'm thinking you might have joined together two dissimilar metals on the housing though.
Not certified, but I've run a few beads in my life, so far. Might check that.
Old 12-01-2023, 11:00 PM   #6
goinbroke2
The control arms were just to get it on the track, at some point I'll be getting adjustable uppers and perhaps go heim joints as well, good idea.
As far as the dissimilar metals, you are correct and I was thinking about that, but I did it anyway, lol. I do a lot of off roading (that's my youtube channel "low range in nova scotia" and I gob together all kinds of crap and then abuse it until it breaks). Not supposed to weld cast iron (what the rear end ears are made of) so there might be "improvements" in the future, especially if it cracks or breaks.
Old 12-03-2023, 10:03 AM   #7
Billy Nees
You really need an 8.8!
Billy Nees 1188 STK, SS
Old 12-03-2023, 10:16 AM   #8
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: U/SA 302 ffffford build
Good morning to all,
Welding cast iron is dicey at best, like hitting a piece of glass with a hammer. I'm thinking you should be able to fabricate what you need out of steel and make it look like the OEM pieces, then weld them to rear axel housing. One thing I've found over the years of trying to fuse cast iron is either the weld doesn't penetrate and breaks off or or the part ( cast iron ) you've welded cracks and breaks. Either of these situations are an accident looking to happen ! We're supposed to be having "fun" not getting ourselves hurt, then also factor in the cost of the Broken Parts Replacement and I think you'll find that building the right parts - the right way will actually be money well spent, the first time.
I'm really enjoying your U/SA 302 FFFFFFord build. Don't take this as a discouragement, this comes from "past experience" and the expense of replacement parts. I understand you'd like to get this project to conclusion but don't rush it. Enjoy your build.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 11-07-2024, 01:57 PM   #9
Chuck Weissberg
Liked 49 Times in 26 Posts
Thanks for sharing...did you think @ someone in the states ordering your comp cam for you?
Chuck Weissberg is offline   Reply With Quote
Old 05-06-2025, 07:38 PM   #10
goinbroke2
Yes, I got the cam and carb from Mike Graham and the converter from Dave Turner. Also picked up a set of 5:14 gears to replace my worn out 4:86's. (as in WORN OUT!!)
Jim Miller
103 U/SA
