Old 08-15-2023, 05:26 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default 327/275 engine, converters, Product Eng fuel system, etc
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $400 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.200 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $1000.00 used. Will include choice of:
PAC-14x2.5x150 suspension springs – NEW
PAC-14x2.5x100 suspension springs – Used
2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Jesel KDR-57100 lifter retainer set set of 8 –400.00
Jesel PLT-53233 – 475.00 new – set of 8 – 225.00
Jesel Dogbone lifters LFD-44002 – set of 16 – 2000.00
Jesel sportsman rocker arms set with stands - 1.9 ratio for LS DR heads set 800.00
ATI/Coan converter
This converter was manufactured by ATI, but freshened and rebuilt by Coan. Turbo spline, 8" steel with Square cut L Stator (35 degree), C Pump. We never ran this, but previously was ran behind a 255HP 350 combination.
$500
Dynamic 7" Converter - Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Product engineering PE4450 – 460 fuel pump New - $600
Product engineering PE1050 – Dual relay wiring harness New - $40
Product engineering PE9000 – regulator and 2 line bypass system for Quadrajet New - $350
Accufab 4 x 2” blade throttle body – Dominator flange – used like new – $450.00
Wilson 1” 4 hole aluminum tapered spacer – Dominator flange PN 024110 - $150 used for test only
MSD - Ford HEI Distributor cap and hold down PN 8408 - $40.00
Energy suspension Poly engine mounts for SBC PN 3.1114G NEW (pair) $75.00
260-223-0157
superstock@live.com
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Old 09-15-2023, 04:01 AM   #2
casrak7
Liked 3 Times in 2 Posts
Default Re: Misc parts, converters, Product Eng fuel system, etc
what might you estimate the ati converter to flash behind a 383 chevy making 550 hp? car weighs 3365 if that matters, 4.30 or 4.56 gear
casrak7 is offline   Reply With Quote
Search this Thread:
Advanced Search
