Old 05-20-2023, 08:45 PM   #1
Liked 10,850 Times in 2,254 Posts
Default I Need Help With A Math Problem
A good friend of mine has a heads up in Stock second round. So for fun I looked at the HP rating of his competition. Much to my surprise the 1970 Camaro 350/360 in Super Stock was de-rated from 360hp to 325hp 12/19/02. I know the AHFS was in affect at that time and according to the rules: a competitor my have requested a reduction in Hp rating. The scale for reduction was based on the year’s previous runs by that combination. The reduction was written as 1.25% if the fastest run was quicker than -.165 under the National index and the class average was below -.550. If the quickest run was -.115 to -.164 under the reduction was 2.25%. So to receive a 35 Hp reduction using the 2.25 % I believe the start Hp would have to be 1555hp. Would y’all mind running the numbers to check my math. And for example a 15 Hp reduction on an engine rated at 420 the start Hp would have to be 666 Hp. I wonder how all this happened with the AHFS in affect?
Old 05-20-2023, 09:37 PM   #2
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default Re: I Need Help With A Math Problem
Wouldn't the 420hp example have started out around 480 hp? I'm on par with Jethroe Clampett math wise though.
Old 05-20-2023, 11:18 PM   #3
junior barns
Liked 20 Times in 14 Posts
If what you say is accurate about hp reduction then you are correct, 360hp at 2.25% should have received 8hp reduction not 35. been that way for 20 yrs Watched this race earlier and if not for a red light itwas going to be a close race! What does that say about the car's hp in the other lane? Both cars are fast and a LITTLE under factored!!!!! LOL
junior barns is offline   Reply With Quote
Old 05-21-2023, 12:01 AM   #4
MR DERBY CITY
Liked 8,131 Times in 1,535 Posts
Larry, you don’t have a math problem …Your problem is Pat C ….If you need HP off a combo contact Jim Hale for help…he can work miracles….
MR DERBY CITY is online now   Reply With Quote
Old 05-21-2023, 07:11 AM   #5
Billy Nees
Yeah, the 383 and 426 Street Wedge got about the same amount of "welfare".
Billy Nees 1188 STK, SS
Old 05-21-2023, 09:58 AM   #6
Dave Casey
Liked 804 Times in 168 Posts
This is just one example among many across all brands that this has happened to. It was over 20 years ago by Larry's info,, so who knows. This particular engine is the original LT1, 360 in a Camaro and 370 in a Corvette, in 71 they had less compression and were 320 and 330 if my memory is correct. I believe that the stock and SS rating may have been both lowered at the same time. There are some running in both stock and SS.
Dave Casey 1330 STK
Old 05-21-2023, 09:43 AM   #7
james schaechter
Both of those cars have the ability to punish the index at will. I think it will depend on who wants to spend some of that hp today.
James Schaechter 3163 STK
