Old 04-27-2023, 11:16 AM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Dana 60 ring and pinion
Need some advice.
I'm installing a used ring and pinion in a Dana 60.
I've had this thing all over and cannot get the ideal pattern.
They do not make this ratio anymore which is why I'm using a used one.
The Dana goes in a 3600lb footbrake Super Stock car.
littlemanjoe is offline   Reply With Quote
Old 04-27-2023, 11:23 AM   #2
dragracerray
dragracerray's Avatar
Liked 208 Times in 89 Posts
Default Re: Dana 60 ring and pinion
Joe,
I learned a trick that makes things so much easier. Hone the Carrier bearings so they slip on my hand (ie are not pressed on). Don't get carried away you don't want the bearing sloppy on the Carrier. My engine guy did the honing.
If you are pressing the bearings on you may not be pinching the shims tight. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 04-27-2023, 11:29 AM   #3
littlemanjoe
Originally Posted by dragracerray View Post
Joe,
That's done. I just realized the attachment didn't go. It's there now.
Mike
Old 04-27-2023, 12:00 PM   #4
Steve Grady
Steve Grady's Avatar
Liked 123 Times in 42 Posts
Set it up by the Pinion Depth markings on the gear, Proper pinion bearing preload, And backlash marked on the gear.
Steve Grady is online now   Reply With Quote
Old 04-27-2023, 01:00 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,924 Times in 578 Posts
I am not seeing any pattern on the ring gear. Put some pressure against the ring gear when checking the pattern. Looks like it might be a mismatched gear set.
Mike Pearson 2485 SS
Old 04-27-2023, 01:32 PM   #6
littlemanjoe
They are a matched set. Just used and I'm not sure how they were installed before.
Old 04-27-2023, 01:42 PM   #7
Jim Cimarolli
Liked 166 Times in 46 Posts
Looks to me like you don't have enough pinion shim. Have you tried quiet a bit more than what you currently have? I would try at least .015 more and see what it looks like.
Jim Cimarolli is offline   Reply With Quote
Old 04-28-2023, 08:35 AM   #8
littlemanjoe
Got it figured out. Thank you
