Liked 67 Times in 28 Posts
The RPM plot line is full of static and looks like a jagged piece of broken glass instead of a smooth line. And the RPM readings are crazy as well. The car Runs just fine. Driveshaft and accelerometer data plots are just fine. This is an intermittent problem with the RPM.
Liked 456 Times in 78 Posts
RPM is read off the tach wire to the ignition box. Check the connection, shouldn't be a butt connector but soldered and terminal into ignition box. Do you have a tach connected also or reading rpm through intelligauge or RP dash? Could be a conflict with tach also, but much less likely. I would check wire for damage and faulty connection
Liked 240 Times in 112 Posts
Had a similar problem with mine & I called Holley. The 1st thing they said was RF interference. Put new plug wires on and got a filter (MSD8830) that goes on the coil power wire, fixed.
Dave Noll, EF/S ,?/SA 6526 |
#4 | |
Liked 282 Times in 78 Posts
Sean
Liked 172 Times in 46 Posts
Sounds like a noise issue. Check how and where the wiring is routed. Stay away from any wires that run fuel pump, water pump, fan, etc. also recheck all your grounds.
Dirk Olson 5036 STK Last edited by Dirk Olson; 04-13-2023 at 12:51 PM. Reason: spelling |
