Old 03-26-2023, 12:24 AM   #1
motoheada1
Liked 4 Times in 2 Posts
Default Cam Question
Hey There
I'm currently putting a combo together that is pretty much a "clean out the shop build. I have a cam, but its got me a little worried and i would like everyone opinion. First some info on the combo.
1966 Chevy II 3000lbs +-
10.5x28 slick or a radial of similar size
5.14 gear and a Glide with a 5K converter and Brake
SBC 363ci 4.030 x 3 9/16
13.8 CR
6.0" steel rod
AFR 1103 heads
Ported super Victor intake
HP 950 carb
Ok now the problem. the cam I have laying around is a Crane TR260/4167-2-4. Its actually listed as a circle track cam. Besides that fact, it seems like it may be a little small for the combo.
specs....260/270 @ .050 on a 104LC .625 lift with a 1.5 rocker
What makes it a "circle track" cam, and does that automatically make it bad for drag racing?
Any help or other cam recommendations would be much appreciated.
Chuck
motoheada1 is offline   Reply With Quote
Old 04-27-2023, 12:16 PM   #2
Steve Grady
Steve Grady's Avatar
Liked 170 Times in 55 Posts
Default Re: Cam Question
Give it a try with a 1.6 or 1.65 ratio rocker if you have the clearance. Decent cam for midrange torque with a P/G.
Steve Grady is offline   Reply With Quote
Old 06-01-2023, 12:36 AM   #3
GTX JOHN
The circle track cams have a closer lobe center.
Often the same cam lobe.
At least in our small block Mopars!
John Irving
741 Stock
741 Super Stock
