Liked 13 Times in 6 Posts
I'm sure this has been covered many times. I have a 327 / 300 super stock engine, flat tops. no crazy compression or anything but it will see some decent rpm. I was gonna run C12 but I will honestly mainly run stick shift races. Whats a good affordable alternative ? Is the Sunoco 112 pretty comparable ? Any back to back tests ?
Liked 240 Times in 112 Posts
Sunoco 110 should be plenty. Better yet C-11.
Always test.
Dave Noll, EF/S ,?/SA 6526 |
Liked 520 Times in 176 Posts
Good morning to all,
As Dave advised always test, every combination requires something different. VP C-12 will work well , I've found on our lower compression engines that the C-11 was slightly better, but again everyone's combination is different ( even within similar engine family's) Timing , Camshaft , Jetting and other outside factors will have a bearing on the "ultimate" fuel for your engine combination. Good luck and enjoy your accomplishments found during your testing. Respectfully, Henry Kunz 1534 H/SA |
Liked 462 Times in 92 Posts
I tested C11, C12 and Sunoco Blue the same day. .001 between all three. That was in the wagon. Maybe a different result in a light car.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
