Old 12-25-2022, 01:07 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default 302 stocker parts for sale
77 302 stocker engine. This engine s multi time national record holder
Multi time class winner. will qualify #1 anywhere anytime.
#1 qualifier and class winner at Indy 2017.
SVO boss block .070 over.
CP pistons/ total seal rings.
cylinder heads have latest "valve job"
Custom camshaft (specs available to buyer).
will pass teardoown, includind rod and piston
scienced out carb that has passed tech multiple times.
VV carb available for this combination.
Has gone 2 seconds under in bracket mode.
In the car. you can see it run. Carb to pan.
$7500 firm
Racepak with 8 O2 sensors /fuel/drive shaft $1500 SOLD!
Pro Trans C-4 aluminum drums and input shell.
Custom ratios (data available to buyer) $5000
Schnieder 8 inch converter $600
turbo action shifter reverse pattern c-4 $350
9 inch rear end 4.86 light weight spool ceramic bearings $2000
9x28 M/T radials 4 passes $300 SOLD
MSD 7530T digital 7 ignition $400 SOLD
Deno 2bbl carb $350
Mike Graham 540 4262
Mike Graham is offline   Reply With Quote
Old 07-24-2023, 03:28 PM   #2
stang35th
Default Re: 302 stocker parts for sale
Is the C4 still available?
stang35th is offline   Reply With Quote
Search this Thread:
Advanced Search
