Old 09-30-2022, 03:38 PM   #1
Cody Lane
Liked 18 Times in 8 Posts
Default Hancock & Lane Engines & Parts Sale
Updated Parts List as of 9/30/2022:
2 - 4bbl Braswell Carbs with top, billet O-ring 4-hole sheer plates, linkage and hardware for SB2 HRE manifold: $1900
Meziere Big Block Chevy water pump black: $325
Star Vacuum pump and bracket: $400 - SOLD
Dailey external oil pumps:
- Single stage pump $400 - SOLD
- Wet-Vac 3-stage pump with 2 vacuum ports: $700
- NEW 4-stage wet-vac pump with 3 vacuum ports: $1000
Rocker arm systems for SB2 heads: NEW
- Jesel complete shaft rocker system for SB2 heads; aluminum solid body rockers 1.75 / 1.7 ratio, bars, stands, hardware. Complete kit: $1900
- T&D complete shaft rocker system for SB2 heads; steel lightweight rockers 1.75 / 1.7 ratio, bars, stands, hardware. Complete kit: $2400
427 LSX engine parts:
- Coated pistons, pins, New stef aluminum oil pan and pick-up, beehive valve springs, retainers, keepers, rocker arms, pushrods, hyd. Roller lifters, camshaft: $1800
2 Complete Wedge Engines:
- 2, record setting Short-Deck engines (316 CI and 321 CI) with the best of everything : $22000 / each
- 316: Fresh, 0 runs
- 321: 4 runs, all this year - SOLD
- Call for more detailed information
PISTONS/ RODS / PINS / RINGS:
SB-2 / used perfect shape / 23 runs:
CP Pistons 4.182 set of 8 / 1.430 c/h
.020 x .020 x 3mm total seal ring set
.927 x 2.250 x .240 wall titanium wrist pins
MGP aluminum rods 5.202 OL x .927 pin with 1.777 bearings included: $1500
CP pistons for Splayed Valve head set of 8 / 4.157 bore x .866 pin diameter with total seal rings: $500
CP pistons for Wedge head 4.165 bore / 1.390 c/h x .927: $400
200 pushrods 3/8" 7.700 to 9.250 lengths: $50 set of 8 or $100 set of 16
Jesel .875 SB-2 tie bar roller lifters dyno time only. Perfect condition: $400
Driveshaft / Chrome moly 51" center to center / 1350 spicer u-joints / 39005-U yoke used one race: $300
5.83 Ford 9-1/2" Gleason Ring and Pinion polished and lightened used / perfect shape: $1300
6.00 Ford 9" ring and pinion US Gear rem finished, cryo'd, lightened / NEW: $800
6.33 Ford 9" Tom's differentials ring and pinion / NEW: $400
Please reach out to if you have any questions.
Thank you,
Cody Lane
(206) 999-8369
cody.lane@hancockandlane.com
Cody Lane is offline   Reply With Quote
Old 09-30-2022, 08:12 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 978 Times in 313 Posts
Default Re: Hancock & Lane Engines & Parts Sale
Which star vacuum pump and bracket to fit what engine?
Old 10-01-2022, 07:19 PM   #3
Cody Lane
Hi Glenn - someone called right after I posted this and has already purchased the vacuum pump and the single stage oil pump; I appreciate your interest!
Search this Thread:
Advanced Search
