Old 09-19-2022, 09:33 PM   #1
edk68
Default Parts
New MSD Plug Wires PN 31193 $80.00
New MSD 3 Step PN 8737 $45.00
New MSD High Temp Boot Kit Angle PN 8862 $25.00
New MSD Module Kit 11,000 RPM Series $25.00
Used MSD Pro Coil PN 8201 $45.00
New CVR Starter SB Chevy Needs Nose PN 5323 $125.00
Jessel Key way Lifter 8 Center 6 - .050 Offset $800.00
Jessel Belt Drive Small Block Chrysler R3
New Belt & Crank Seal Bracket for Dist. No Dist. $1,000.
Flexalite Trimline electric fan 15" $60.
New Felpro VC Gasket PN 1646 Sm. Chrysler $35.
Reactor Flywheel 142 T Chevy Bolt SFI" Exp. New $100.
Hurst Line Lock $50.
9" Richmond 6.50 Pro Gear Lightened small Pinion 9 passes $275.
2 Angle Tak Window Nets 18" X 23" SFI Exp. $20. Each
Coan 8" Converter Powerglide stall 6800 $600.
Comp Cam Push Rods 125 Wall DBL Taper
1 Set of 15 8.100 $125.
1 Set of 16 8.100 $ 175.
Trend Push Rods 125 Wall DBL Taper
16 7.963 $225.
10 8" $150.
5 7.963 $75.
5 7.938 $75.
16 Unknown MFG 8" $100.
Buyer Pays the Ride
No reasonable offer refused
Contact Ed 815-909-8827
edk68 is offline   Reply With Quote
Search this Thread:
Advanced Search
