Liked 51 Times in 30 Posts
going from non-adjustable rockers to adjustable on my 400 stocker hydraulic cam, using hydraulic until new motor is ready, how do i adjust them? back in the days (small block chevy) ran engine backed off until they clicked then tighten one turn,
put a pushrod thru stamped steel rocker |
Liked 930 Times in 264 Posts
Been awhile, but on hydraulics, we always just went to zero lash. Preload beyond that made it possible for the lifters to "pump up" at high RPM and prevent the valve from fully closing.
Might be a hillbilly way to do it, but we would run the valve adjustment just like a mechanical cam, but would loosen the adjustment a touch until it had clearance, then spin the pushrod with fingers while slowly tightening the adjustment. When the pushrod got snug, stop. Done. Like I said, been awhile. |
Liked 49 Times in 22 Posts
Turn the adjuster until they are zero lash, and then add 1/2 to 3/4 turn.
Steven Barnes Stock 704 N/SA |
Liked 11,017 Times in 2,265 Posts
You could pull the lifters out with the heads on, shim the lifter to very limited or no travel reinstall and set as solids. That is if you have stock heads.
Liked 12 Times in 6 Posts
First know how much preload works best for your application. Second divide the number of threads per inch of your adjuster into 1. that tells you how much preload per turn off adjuster. as an example if you have a 20 tpi adjuster that's .050" per turn. if you want .012" preload that would be 1/4 turn past zero lash. hope this helps. Dan
Liked 5,153 Times in 1,967 Posts
First thing I would ask is what height solid are you using to check the cam lift with?
