Thread Tools | Search this Thread | Display Modes |
Liked 130 Times in 20 Posts
Lots of parts for sale-
SOLD-Sealed 5 gallon pail VP C-25 fuel $125 SOLD-Sealed 5 gallon pain VP C-14 Fuel $90 -Small block ford 10" Mcleod Softlok single disc clutch, setup by Hyatt, has runs on it but in great condition, disc still .360 thick, normal wear, 1 3/16-18 spline disc, 164 tooth flywheel, 28g counter balance. Total assembly weight 32lbs $800 -Lakewood bellhousing for small block ford, Jerico pattern, great condition. Includes backing plate, throw-out bearing, Lakewood fork #15525 and is in the Lakewood box. SFI tag is punched April of 2014 $375 SOLD-Moroso 20105 6 qt LS oil pan, fits 1955-1987 GM cars (except G body) 5 3/4" deep, cast aluminum, used in my camaro last fall only, like new. $300 -CSR Platinum pro Starter 100P chevy V8 153 or 168 tooth flywheel, has been rebuilt with newer powermaster solenoid, starter gear in great shape. $150 -Product engineering fuel pump and relays used $300 https://product-engr.net/collections...acing-pump-kit -MSD ignition system- 7AL2 ignition box / two step module 8739 / Pro power coil 8201 $350 -Mr Gasket 5903 SBC 1955-91 ultra seal header gaskets, I have 4 new sets in the packaging, get all four sets for $100 -Steel driveshafts 3 1/2" diameter- 43 5/8" center of joint to joint, 1350 ends Jerico yoke $125 40 7/8" center of joint to joint, 1350 ends Jerico yoke $125 SOLD-Autometer pro-comp 2 5/8" ultra lite silver 0-1600lb electrical brake pressure gauge pn#4467, gauge was recently removed form my car works perfect, comes with gauge, wiring, sensor and carbon fiber cup mount pn#2151 $100 -Autometer gauge set- 5" pro comp II memory tach 9k rpm tach, Sport comp 2 5/8' 0-100lb mechanical oil pressure gauge / Sport comp 2 5/8" mechanical 120-240 degree water temp gauge. three gauges sold together $150 -2 JAZ plastic race seats with black covers $150 -ARC 3700 overhead pro stock 6 fused switch panel, roll bar mount $110 -Grant 15" formula GT 15" silver steering wheel with black grip, also includes IDIDIT quick release hub. $100 -Pit pal oil rack #312, 24 quart oil tray 60"x 4 3/8" $50 All items can be picked up, shipped or I can bring to Norwalk pts meet or GLSSA race in Stanton the following week. Call, text or email for more information or pics of any of the items. brad@zaskowskibuilders.com (616)437-4958
Brad Zaskowski 3697 STK, SS Last edited by Brad Zaskowski; 06-01-2022 at 12:41 PM. |
Liked 1,966 Times in 595 Posts
Hi Brad. I am interested in the fuel pump. Can that pump be used with a carburetor?
Mike Pearson 2485 SS |
Liked 10 Times in 8 Posts
Good morning Brad, you have a PM for the C25
Thanks, Frank
F Federico NHRA J/SA |
