Liked 58 Times in 16 Posts
Trying to see what the general consensus is on recommended gear ratio would be in conjunction with tire size.
396 / 325 Automatic 3 speed 2.75 low 4:88 or 4:56? 92.5 “ or 94” Hoosier radial? Would it be the same for 360/340hp (bigger cam) as well? Wanting to hear about real world tests/results? Help appreciated. Thanks in advance.
Overkill is Under-rated |
Liked 2,518 Times in 702 Posts
4.56 and either tire size would be my suggestion.
I think the 325 / 396 is not a super high rev combo.
Liked 26 Times in 11 Posts
Find a chassis dyne throw it on there see where the motor is actually make power and torque . Unless you your combo is built identical to others running the same stuff you are just guessing where it wants to be . I would think someone would chime in that runs that combo I know there are a lot of them out there
Liked 225 Times in 88 Posts
There's only 100-150 RPM difference between the 92.5 & the 94 .
Liked 166 Times in 71 Posts
Mine likes 4.33 in F weight, 4.56 in G weight. They don’t have a ton of RPM on tap. With the 350hp combo 4.56 would likely be okay in the lighter class, but the cam doesnt seem to increase RPM range by much.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
