Liked 21 Times in 6 Posts
looking for a motor plate designed to pull a LT 1 out of a 1997 Camaro thanks
Liked 335 Times in 182 Posts
Look at ebay item 230195365220---Will this work???? Comp 387
Liked 89 Times in 19 Posts
That e-bay item is for an LS1. It won't work on an LT1. Do a search for "Happy Hooker." In addition to a possible link to some good-time girls, you'll eventually find a reference to a device that bolts to the fuel rail bosses on top of the LT1 manifold. I've never used one of those myself but I've been told that they work very well.
Good luck |
On second thought, before this thread deteriorates entirely, check the following URL:
http://tpis.com/index.php?module=cat...y=Happy+Hooker |
Try TPI Specialties
Website tpis.com Address 4255 creek rd Chaska, MN 55318 Tel 952-448-6021 Fax 952-448-7230 Lotsa nea t stuff there---Sell the engine plate for $49.95 Also on ebay item 270135625201 looks just like the other item I told you about but with a few more holes in it---Comp 387 |
Liked 557 Times in 217 Posts
I used a home made setup. A square piece of stock about 1" by 1" and wider than the engine, crosswise. 4 chains attached to the ends and I bolted the chains to the 4 corner exhaust header holes. I use this same setup on any engine with a real tall t-ram style intake. I attached it as tight to my engine hoist as I could get it and also added an extension to my hoist. Had to add weight to the back of the hoist to act as a counterweight. The holes in the intake for the fuel rails are very small.....The plate would be easier but I used what I had and it worked fine. I removed all the stuff on the front of the engine.....water pump - housing, dist. cap and balancer.
Thanks guys this should help
