Liked 10,711 Times in 2,230 Posts
Any ideas ?
Could it be when the combustion occurs the bearings take a hit in the middle causing the outer parts of the shell to move away from the housing just slightly and then return causing a fretting action and transfer of metal, from shell to housing bore. |
Rods out of round or inadequate bearing crush. I'm just spit balling ideas.
Liked 880 Times in 311 Posts
Bearing type/part number and rod type and application?
General answer: Fit in housing bore Pictures?
Adger Smith (Former SS) |
Manley rods, King not as bad as Clevite 77, housing bore round according to AG 300. No pictures all the evidence is gone, removed.
How is bearing crush measured and where can the specifications be found? Oil is semi synthetic |
Liked 347 Times in 151 Posts
I don't know if it's correct or not, but I use a height gauge to measure each shell and to verify that the shells are square, which I've found some that are way off. I've had rods on the small end of spec as well as the big side both do it.
Phil Molski PMR Performance S/C 1623 |
Liked 333 Times in 180 Posts
using too thin of an oil ?---oil is not "thick" enough and not enough "pressure on the bearing" to keep the proper spacing between bearing and crank
#7 | |
Liked 734 Times in 385 Posts
Larry, Are you saying the Micro Welding is happening near the ends of the bearing? Stan |
