Old 06-12-2021, 08:55 PM   #1
Mike Hedger
Default Onan 5.5 EFI code 12 help
Does anyone have experience with a code 12 on an Onan (over voltage)? I have looked at the obvious things the plug to the trailer, checked voltage for the few seconds it runs 125-127 then it shuts down. Have replaced the brushes and gen amarteure bearings about 150 hours ago. Checked brush connections they are tight. Changed pre fuel pump filter just because. If I flip the breaker off it might stay running then flip back on when running and it produces no voltage from the output.
Any advice would be great.
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 06-16-2021, 09:12 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Onan 5.5 EFI code 12 help
Remove the 1 10 mm bolt holding the black plastic cover/carrier that has the rocker switch and the breaker
Now you can clip a meter on the input side of the breaker but with it off.
Your just isolating the machine from anything downstream and trying to see what the voltage and frequency (HZ) is when it does run.
From all the things you said you did, I would plug in another known good control board to see if there is any change.
I fix them so I have lots of test boards.....
The high voltage fault code 12 says numerous things to check but most of them are not clear. Supposed to be 138 volts to trigger that fault code.
A Rotor or stator issue not out of the question...
Right now parts availability for many machines is very bad.
I just fixed a 5.5 with a seized upper rotor bearing and Onan does not sell those bearings separately....It is possible to replace them though and I did that repair a number of times.
Your machine should have ROM.....Run Only Mode.....allows you to run it even though it is not making AC output....
Starts, shuts down in a fault, you restart it within a minute and it will run with NO AC output and if it has a lighted rocker switch, it will be blinking rapidly telling you it's in Run Only Mode....
You can do things like artificially energize the field at the brushes with DC voltage to test the rotor and stators ability to produce AC voltage normally...
I use a variable power supply but a 12 volt battery will work....
Onan does list that procedure and what the AC output should be approximately.....with 12 volts in.......
A service manual would be real helpful and you can buy those online for maybe $20
Rich Biebel
S/C 1479
Stock 147R
