Old 05-06-2021, 10:17 AM   #1
Dave1695
Liked 15 Times in 11 Posts
Default replacement Stock heads
The 291 castings on my 67 350 Stock eliminator engine are about used up. Of the listed acceptable replacement castings (Dart, RHS, World), is there any one part number that is a better starting point, than the rest. Finding old original castings worth buying, has not been successful. Appreciate any input or personal experience.
Dave1695 is offline   Reply With Quote
Old 05-06-2021, 11:26 AM   #2
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Default Re: replacement Stock heads
Factory 462's and 041's are accepted on that application too.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 05-06-2021, 11:51 AM   #3
Henrys Toy
Liked 520 Times in 176 Posts
The small valve ( 1.94/ 1.50 ) 186 castings should also be good.
Check for ex. seat cracks in the two center cylinders and if they are not cracked, those would be about the Best Stock castings to use.
As per usual if you can find a couple of pairs, crack check and flow test then picking the best pair. You should be happy with the final outcome.
Henrys Toy is offline   Reply With Quote
Old 05-06-2021, 11:56 AM   #4
Bobby Lundholm
Liked 128 Times in 50 Posts
If you can find older Dart castings those would be best. Any of the new Dart castings are 180 cc + intake runners. You can't make the small enough to get to 165.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 05-06-2021, 05:09 PM   #5
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Please correct if I'm wrong but I didn't think any of the replacement heads were legal for a stocker because of the volume numbers . Am I wrong?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 05-06-2021, 10:18 PM   #6
SDT1DYI
Liked 456 Times in 148 Posts
They are legal so long as the runner volumes meet the OEM stated requirements. 165 CC SBC intakes are difficult to get down to. 161 CC is near impossible.
RHS heads I don't believe are manufactured any longer?
Hard to understand how some of these heads become approved by NHRA when in fact none actually "in a out of the box condition" are legal.
So a lot of machining and innovation is necessary to get them to pour correctly.
Making it expensive compared to using a good condition OEM casting and you then have no HP penalty.
Steve Teeter STK/SS 620
SDT1DYI is offline   Reply With Quote
Old 05-07-2021, 09:10 AM   #7
Dave1695
Some aftermarket castings are accepted with a 5 HP penalty. I have been shopping for a pair of untouched castings without success so far. Will look for older Dart castings now too, thanks guys!
Old 05-07-2021, 10:43 AM   #8
Bobby Lundholm
Give Chris Hardy a call 231-740-5862 he does my cylinder heads and he's a wealth of knowledge.
Old 05-07-2021, 12:16 PM   #9
B/S 428
Liked 154 Times in 34 Posts
All American Classics in Vancouver Wa has used OEM heads.
B/S 428 is offline   Reply With Quote
