Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 04-02-2021, 11:18 PM   #1
rod
Liked 20 Times in 15 Posts
Default wire feed welder ?
I have HF AC welder. it splatters. does the DC welder do more or less?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-05-2021, 09:42 AM   #2
novassdude
Liked 136 Times in 49 Posts
Default Re: wire feed welder ?
Is it a wire feed? Solid wire or Flux core? or Stick welder?
novassdude is offline   Reply With Quote
Old 04-05-2021, 09:11 PM   #3
rod
it is an AC flux core wire feed. welds good for what I do. just lots of berries
in corners or tight areas.
Rod
Old 04-05-2021, 09:14 PM   #4
There are better grades of flux core wire..Hint: Don't use the stuff that comes with it.
Old 04-06-2021, 10:15 AM   #5
1matcoman
1matcoman's Avatar
Liked 378 Times in 143 Posts
Thumbs up Re: wire feed welder ?
^^^ this !!!
1matcoman is online now   Reply With Quote
Old 04-06-2021, 10:37 AM   #6
novassdude
Rod
I am far from an expert but I know on mine (Century welder) using flux core I always get a good amount of splatter. Same welder using gas is much cleaner. I never did try different brands of wire.
Old 04-07-2021, 10:24 AM   #7
SSDiv6
I have a Century (Lincoln) Flux Mig.
Like Mark said, the amount of splatter depends on the brand of the wire. I only use Forney and Lincoln and the amount of splatter is minimum.
Old 04-07-2021, 04:00 PM   #8
4ktowman
Liked 63 Times in 2 Posts
I have used anti splatter spray helps a lot to clean splatter off ...plus smells like frying fish when welding...lol
4ktowman is offline   Reply With Quote
