Old 01-03-2021, 01:09 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default garage cleaning parts for sale
1966 289 hipo crank (std) with balancer, counter weight, crank gear set of 289hipo/boss 302 rods polished, bushed, arp bolts set of trans am dan gurney rods 5.315 polished, 7/16 bolts, bushed, cut for 300 six cylinder bearings, also have a set of ross dome .30 pistons for them pair of 69/70 351W heads, port and polished, screw in studs, cut for 190/160 valves pair of 69 302 heads, screw in studs, cut for 190/150 valves older sets of flat top forged super stock 289 0.60 pistons 2 older roller cams super stock, one is comp, one is ultra dyne original B/A ford intake manifold 289/302 original cobra jet 9inch N case (marked inside not outside) with 5/8 cap screws 9inch mini spool 4series gm posi with 4.56 gears A4 boss 302 replacement block (mid 80s) steel caps, filled, 0.60 over, decked 23spline henry spool and axles for 9inch ford pair of holeshot front wheels 15x3.5 1.78BS gm pattern pair of crager front drag lights 15x3.5 2.25BS multi pattern both are very light all parts stored in garage and in good condition have lots more just ask pics available, just ask 610-937-4564 Bob
'65 Mustang SS/L & L/SA
Search this Thread:
Advanced Search
