Old 12-07-2020, 06:05 AM   #1
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Default 70 Nova Stocker
Sold sold sold
1970 Nova. Titled. Moser 12 bolt with lightweight spool, 35 spline gun drilled axles, 5.13 Gear, wilwood disc's with Wilwood Master Cylinder. Cal-Tracs, 3.5" drive-shaft with 1350 joints, TH400 crossmember, Holley pump, braided lines, alum 5 gal tank. Comp Eng. Regulator with sample valve. Two engine compartment motor bumps and fuel sample switch. Weight bar, weight box, cage, Buckets, MSD 7AL3, Auto Meter Tach, all gauges, Auto meter Stack System, Two master cut-offs, AGM 16v battery, Weld Aluma-star wheels, New light weight Hoosier slicks and Frontrunners. QA-1 Rear shocks, Tinnin adjustable fronts. Line-Lock. Super straight with good glass. Cheetah shifter. Clutch pedal with Micro switch if so inclined.
$16,500.00
Will E-Mail pic's, (Can't upload) Also on RJ. AD 184124825
505-720-2377
Dan
SC 707Y
Dano is offline   Reply With Quote
Old 12-08-2020, 07:19 PM   #2
Dano
Dano's Avatar
Default Re: 70 Nova Stocker
SOLD
Thanks class racer!!
SC 707Y
Search this Thread:
Advanced Search
