Old 11-15-2020, 07:45 PM   #1
Randy Wells
Liked 1,144 Times in 354 Posts
Default Lug Nuts
I am putting 5/8" studs in the rear axles, they currently have 7/16 and I can see some issues with them, my Centerline's, have a 60 degree conical seat. What do you all use for lug nuts, shank type or the conical seat type. Would have to enlarge the holes in the rim if I went with shaft lugs.
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 11-15-2020, 08:18 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Lug Nuts
Randy, measure the wheel lug nut hole because it may already be 5/8.
Larry Woodfin 471W
Old 11-15-2020, 08:35 PM   #3
Randy Wells
Larry, the holes are .562 or 9/16. I am thinking of just going with the 1/2" studs don't think this I/Stick car needs 5/8" we had 5/8 on our 67 D/Stick car, thought I would put them on this car but don't really want to drill the wheel holes. May have to ream them a little for 1/2" shank lug nuts.
Randy Wells
I/S 5628
Randy
Old 11-16-2020, 08:24 PM   #4
Jack Zimmerman
Liked 11 Times in 6 Posts
Something that hardly ever seems to get mentioned about the typical 5/8" wheel drive studs that a lot of us use is that the shoulder that fit's into and locates the wheel is actually 11/16" in diameter. This is the same diameter as the shank on a standard 7/16" or 1/2" threaded straight shank lug nut made for racing wheels. The 5/8" part of the stud is just the thread size. So if you want to use 5/8" drive studs, the holes in the wheels need to be 11/16" diameter. If the wheel is made for use with conical lug nuts it may not work with the 5/8" studs unless it's drilled out and has enough material left to bear on the stud without deforming under hard acceleration.
Jack Zimmerman is offline   Reply With Quote
Old 11-16-2020, 08:54 PM   #5
Randy Wells
That is why I am going to go with 1/2" studs, don't want to drill the wheels. Thanks Jack
Randy Wells
I/S 5628
Old 11-17-2020, 08:51 AM   #6
Liked 11,030 Times in 2,266 Posts
Something to think about, cost of 5/8 studs vs repair cost and body work.
When I broke my 1/2 studs it ruined a 71 Cuda bumper, painted Grill, and a gilled fender. The grill was just north of two grand.
