Old 06-23-2020, 11:17 AM   #1
StompNDump
Default RPM drop while on Stop
Running an APD Max Speed carb with built in stop and ive noticed on my logger that the car will drop roughly 100 to 120 RPMs while on the stop. Is this normal or has anyone else had this issue.
StompNDump is offline   Reply With Quote
Old 06-23-2020, 12:04 PM   #2
J&S Racing
Liked 319 Times in 82 Posts
Default Re: RPM drop while on Stop
Max speed a great piece but very finicky imo..
Are you running a 02?
Old 06-23-2020, 12:40 PM   #3
StompNDump
Not running an 02 just yet, have a set up coming.
Old 06-23-2020, 12:51 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Does the RPM drop coincide with the shift?
S/ST 51
S/C 53
Old 06-23-2020, 12:55 PM   #5
StompNDump
It doesn't appear to coincide with the shift.
Old 06-23-2020, 01:18 PM   #6
J&S Racing
02 is a absolute must for this carb!!! Make sure you place them 12ish” off the head.
More than likely its your front jets.
Old 06-23-2020, 02:16 PM   #7
StompNDump
Whats your recommendation of what I should try with the front jets?
Old 06-23-2020, 04:50 PM   #8
J&S Racing
I don’t have my log book handy and I only made a few hits last year so I Just can’t remember what way you gonna go for the loss of RPM. Really need to see what the A/F is doing on the stop.
Until you get the O2s I’d play it safe and start by giving it more fuel and see what it does. If it gets worse go down a few sizes from what’s in there now.
For the most part the front jets control what its doing on the stop then you tune the restrictors behind the power valve and rear jets for down track.
Old 06-24-2020, 01:02 PM   #9
sully3358
Liked 10 Times in 7 Posts
need to go smaller on front jet
what is your current setup? main jets front and rear and restrictor sizing in front?
sully3358 is offline   Reply With Quote
Old 06-24-2020, 03:28 PM   #10
Charlie Yannetti
Liked 192 Times in 83 Posts
What kind of car are we talking about??.. my 27 Roadster has a torsion bar front end, and when it touches down when the stop comes on, it unsettles the floats, and causes an RPM drop similar to yours.. we have tried just about everything to improve it, even putting jet extensions on the front jets.. helped, but not a real fix.. the only thing seems to work for me, is increasing the cruise RPM.. but then you have to add numbers to the timer.. not always a good thing, and can affect MPH if to many numbers are added..
You can also head to left field, and fiddle with the timers and shift points, but don't get lost out there..
The up side is that I can over-lay my graphs, and they are almost identical run to run.. SOOOOO, I dial it, and let go of the button..
Charlie Yannetti is offline   Reply With Quote
