Old 06-01-2020, 10:24 AM   #1
StompNDump
Default Do these stop numbers sound right?
582 in a Davis Roadster, All out runs 850's
Dedenbear Delay Box, APD Max Speed carb
Launch 5200
Timer A1 - .125
A2 - 3.050
Shift (Timer) B1 - .200
B2 - .300
4100 RPM while on Stop
MPH was 152 and car ran a 10.56
Changed Timer A2 - 2.050 and car ran 10.19
I just got this car turn key and im kinda new to all this. Just wanted to see if these numbers looked correct or if there is something that looks incorrect. The 582 is nothing fancy, Id say a mid range 582 with the weakest link being BB2X Xtra Heads.
StompNDump is offline   Reply With Quote
Old 06-01-2020, 12:17 PM   #2
57 Vette
57 Vette's Avatar
Liked 38 Times in 14 Posts
Default Re: Do these stop numbers sound right?
Is the Davis 57 model or a C5? I have a 57 Davis that has a 582 Head Hunter engine that makes around 1060 H/P. # 1 timer .007 # 2 3.500
Shift .020-off .040 I leave at 5,200 to 5,600 Rpm. All these numbers are depending on the Density Alt.
57 Vette is offline   Reply With Quote
Old 06-01-2020, 01:02 PM   #3
StompNDump
Its the C5 Davis
DA was 1803 Ft
Old 06-01-2020, 01:41 PM   #4
57 Vette
57 Vette's Avatar
The C5 model Davis is a good 100 lbs lighter than the 57 model and has better aerodynamics!
Old 06-01-2020, 02:45 PM   #5
StompNDump
It was those numbers that had me guessing. I figured a engine that size running 8.50s would have carried more in the timers or at least close to where they were set, but unfortunately that ended in a 10.56 and 10.19, So it looks like this set up may only carry a second or so on stop.
Old 06-02-2020, 08:43 AM   #6
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
If it were mine, I'd make the 'Stop On' time later and/or increase the RPM on the stop some so you can carry a little more time on the stop.
It is best if you can always be on the stop through the 60' timer so you have something that should stay constant run-to-run.
S/ST 51
S/C 53
Old 06-03-2020, 05:07 PM   #7
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Have you seen the car run 8.50's or run it? Just curious if it did or you were told it did. 152 seems a tad low on MPH for a car capable of 8.50, especially a car set up for super class stuff.
sst7250 is offline   Reply With Quote
Old 06-04-2020, 08:51 AM   #8
StompNDump
Actually the car has run 8.40 and an 8.37, this has been done with me at the end of last year in good air. This past weekend while running an 1/8 mile race it was dialed 5.45 all weekend long in the heat of Texas.
Old 06-04-2020, 12:55 PM   #9
sst7250
sst7250's Avatar
I am surprised you are loosing that much MPH then. Was just curious I know most of the S/G built deals don't usually ET well off the stop but have good MPH. I would think running 8.30/40 you should be running mid 160's all out. I lost a TON of speed with mine but the car was also capable of going 3 seconds under the index. Also I would think you would be on the stop longer to kill 1.5ish seconds.
My only advice is this. Kill it as soon as you can as hard as you can. Get it on the stop as soon as you possibly can to be able to hit the tree. Shift it on time as soon as possible, use the shift time to get to an "ideal" 60' time. Id be looking to keep shift to .5-.75. Stop RPM between 4-4400 seems to be where everyone wants to be. IMO it is combination dependent to be repeatable. Your converter will be your friend here and make take some tweaking to make it happy and as fast as can be. If its to tight it will come off the stop and just lay there for to long costing MPH. MPH is the name of the game, try to get all you can out of your combo. Of course while being repeatable and predictable. Give it time you will find a sweet spot
Old 06-04-2020, 02:24 PM   #10
StompNDump
One thing that I believe was an issue is the tight converter. While running an all out 1/8 mile race and launching at 4200 the converter was flat and seemed lazy. We upped the launch to 4600 and 4800 and the date looked much much better as far as the curve. So I am thinking with the RPM of 4100 on the stop it may be slightly below where I need to be while on the stop. Maybe an increase to 4400 will be where I need to be.
