Liked 286 Times in 73 Posts
My father has a 1966 Plymouth, converted to Mopar electronic ignition. We believe that the car has previously been raced, but he drives it on the street. It has the above voltage regulator on it, and he thinks the battery went bad way to quickly. I researched this on another site. A third of the people say this is a drag race only item, a third say it is fine to use on the street, as long as you ground it, and the last third claim to have used it on the street for years. Can I get some advice on this?
Thanks, Greg |
Liked 25 Times in 16 Posts
You can get a stock replacement voltage regulator for the 1970-1980s cars like a Standard Motor Products VR-125. They seem to be reliable if it is wired correctly.
https://www.summitracing.com/search/...dge/model/dart
Mopar 2 Ya! |
Greg: I believe that # is "Constant Charge" voltage regulator is a race piece.
If you drive it on the street for extended periods of time...It will severely shorten the life of the battery. It inputs full output of the alternator's available amps into the battery and literally boil it to Death after a period of time on the road!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-20-2020 at 02:45 PM. |
Liked 292 Times in 147 Posts
John is correct here.
You need to use a 1966 replacement regulator with that setup. The Mopar instructions for the electronic ignition kits are very poor for the earlier cars. I just went through this a few years ago with my '65 Coronet. The part number you need is a Wells VR706. It's actually a modern style retrofit with a circuit board instead of the wire coil and point design. |
Liked 817 Times in 342 Posts
They are for sale on Amazon and this is the description:
"To ensure your ignition and electrical systems can provide maximum. performance, install a Mopar constant output voltage regulator. Voltage is held at a constant 13.5 volts. For race applications only. Mopar parts and accessories are engineered and built specifically for your vehicle providing the precise fit, finish and quality you can always expect from Mopar to keep your vehicle looking and running its best." |
Thank you, everyone. This is not the first thing that we have found on this car that has been "less than ideal". Still, it's a fun car!
#7 | |
Liked 242 Times in 81 Posts
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
