Old 02-15-2020, 11:13 AM   #1
hevychevy
Liked 2 Times in 2 Posts
Default 1974 Nova I/SA
1973/1974 Nova NHRA stock eliminator race car
$17,500
I would also sell several different levels -
$9500 without wheels
$11,000 full roller
$12,000 with tranny
$15,000 with backup motor
$17,500 with new dart motor in it.
Run as 1974 in I/SA - .40 under 50lbs heavy
Engine -
New dart block 350
PAC springs
Bullet Cam
Thin ring set
All build details available
11 passes
Transmission -
New Long Motorsports Th200
Cheetah Valve body
New Ultimate converter
3 passes on trans and converter
Cheetah shifter
Wheels -
Weld Aluma stars front and back
Hoosier light weight radial sidewall slicks
Brakes -
Wilwood disc brakes up front
Aerospace disc brakes rear
Strange master cylinder
Brake pressure switch to fire two step
Suspension-
AFCO double adjustable shocks up front
Calvert shocks rear
Cal-trac rear suspension
Landrum springs
Global West Del-A-Lum bushings up front
Rear-
10bolt with moser axles
Moser spool
5.13 gears
Fuel System-
MagnaFuel pump
8an braided steel front to back
Fragola fittings
Product Engineering high flow regulator
Deano’s quadrajet
Electronics -
Leesh power board
MSD 7AL2
MSD 2 step
Moroso switch panel
All new wiring throughout car
hevychevy is offline   Reply With Quote
Old 02-17-2020, 09:55 AM   #2
FLEMING
Liked 54 Times in 25 Posts
Default Re: 1974 Nova I/SA
Let me know if you decide to sell spare motor
FLEMING is offline   Reply With Quote
Search this Thread:
Advanced Search
