Liked 43 Times in 11 Posts
Coan 7" bolt together aluminum convertor. Choice of #4 or #5 pump. Choice of 30-13, 30-15, 30-17 or 30-17-22 stator - $3200. Additional stators @ $300 each
Sale pending Protrans - 245/145. all new steel and frictions, case has a hairline crack - non pressure area and leaks - needs to be professionally welded. Previous owner had epoxied - I've had it 5 years and been fine but should be welded versus epoxy, I can send pictures - $3000 sale pending MW 6.20 third member, 3.812 aluminum case, lightweight 40 spline steel spool, MW steel yoke and large bearing support, light weight / back cut pro gears, Racepak 2 magnet collar - no pickup- $1200 sale pending MW 5.83 third member - same specs as above - $1200 sale oending Monocoque Wheel set super lite style (round holes) - need a lil TLC - (center beads need to be resealed). Fronts 5 x 4 3/4, rears 15 x 14 dual pattern - $800 (4) Hogan SBC Shortdeck 2x4 manifolds - $300 each All prices plus freight - Can by delivered to Phoenix. Pictures available on request. Contact: Alan @ 831-595-4720, call or text is fine. Thank you, Alan. Last edited by Alan Freese; 02-15-2020 at 09:07 PM. |
