Old 01-12-2020, 10:05 PM   #1
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Default Stock and Super Street....
Ok....speaking hypothetically You have a car that runs under index (0.5ish) in a stock auto car. Said car would cover super street by a couple #'s, you want to run the super street class without cutting up your BS/A car and still with little effort run the stock class. If you had this situation, what would "you" think the appropriate process would be to accomplish this? Don't worry about being rude with your suggestions. I can sift the wheat from the chaff………….
SC 707Y
Dano is offline   Reply With Quote
Old 01-12-2020, 10:13 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,251 Times in 989 Posts
Default Re: Stock and Super Street....
Assuming you don’t run over 135 MPH it’s just a matter of putting a S/ST number on it. But suggest if you don’t have a reliable method for hitting the 10.90 you could be a first round duck.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-12-2020, 10:22 PM   #3
Dano
Dano's Avatar
Hi Jim, more concerned with the launch aspect. My car heaves the line quite a bit on the launch with a steep rear gear, (5.13) How to control that without hindering the run? I see you run S/SS/SST?
SC 707Y
Old 01-12-2020, 10:30 PM   #4
Dano
Dano's Avatar
car is cert'd 8.50...personally, licensed to SC
SC 707Y
Old 01-12-2020, 11:02 PM   #5
Dano
Dano's Avatar
Crickets.....
SC 707Y
Old 01-13-2020, 08:14 AM   #6
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
Should be fine. Worst part would be the .470 pro tree. Most quick stockers with the low trans gears would probably be fine. Need a diaper also
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
