Liked 10,853 Times in 2,255 Posts
Anybody have any experience or used such? My top ring to land ware pattern is lacking making 360* contact. 2nd ring without anodizing on land has nice ware pattern as if it was a top ring. It looks like the top ring is allowing a lot of cylinder pressure to get to the second ring. Both are steel rings. I will lap top ring on surface plate to check for flatness.
#2 | |
Liked 226 Times in 137 Posts
Hard anodizing if done correctly is good.You may not have enough radial tension and the ring is not sealing to bore if cylinder pressure rises very quick! Have you ever run Engine with a Blowby meter?
W Quote:
No but I have one. I will have to try it next time on the dyno.
Liked 29 Times in 14 Posts
You might want to check ring groove waviness. You will need to ask the supplier what the specification is and measure at a machine shop or send back to the supplier. The anodizing is normally used to reduce wear in the piston ring groove for production engines.
Sending the piston back to the manufacture will be like asking the fox to watch the chicken house. It would take a little bit of work to make a piston holding fixture that would repeat to .0001. Its way easier to check ring thickness, I'm seeing .0003 variation in ring thickness.
Liked 54 Times in 24 Posts
I questioned Hard Coat Anodizing with my Diamond Rep a few years ago. His statement on the subject was that the Hard Coat Lands will not seal as well as a properly machined , bare aluminum Land.
He said the up side of the Anodizing is greater longevity. As for if you want to send your Pistons out for Land work, you can consider Rebco Machine in Wichita, KS. They specialize in Piston work. Outstanding quality.
Todd Gross 3323 FS/E,F |
