Old 10-16-2007, 08:11 PM   #1
keith ohanesian
Default wanted
I'm looking for the fuel tanks that go in the truck beds.. People that make them or used ones. It would have 2 fit an 04 f-350 thanx
No prep is king
keith ohanesian is offline   Reply With Quote
Old 10-16-2007, 08:39 PM   #2
Shane Carr
Default Re: wanted
Keith try northerntool.com or tractorsupplycompany.com.
They list them under fuel transfer tanks.
I got mine from northern tool, 60 gallon tank with storage on top of the tank about $600.00.
The brand name of mine is RDS.
Shane Carr is offline   Reply With Quote
Old 10-16-2007, 08:40 PM   #3
FED 387
Liked 335 Times in 182 Posts
Default Re: wanted
For diesel or gas???? There is a co. in texas advertises in Dragster but they are EXTREMELY expensive--If you get gas make sure it is DOT accepted--not sure how it works with diesel-----If you have a truck salvage yard in the area you can usually pick up used Semi tractor tanks for about a buck a gallon maybe less if you shop around--Otherwise if you have any Farm supply stores in your area they carry them---also look on ebay under aluminum fuel tanks or truck fuel tanks might be able to pick one up in your area---Comp 387
Old 10-16-2007, 08:49 PM   #4
keith ohanesian
Default Re: wanted
thanx guys
No prep is king
Old 10-16-2007, 11:41 PM   #5
RPinoski1
Default Re: wanted
Try www.Supertanks.com. Their tank replaces your old tank with a larger one and you don't lose the bed space.
RPinoski1 is offline   Reply With Quote
Old 10-17-2007, 08:45 PM   #6
Mickey Whaley
Wink Re: wanted
try these nuts
Mickey Whaley is offline   Reply With Quote
Old 10-17-2007, 10:18 PM   #7
keith ohanesian
Default Re: wanted
yaaa hheeeeheheheheh
No prep is king
Old 10-19-2007, 05:08 PM   #8
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Default Re: wanted
Keith i have two 150 gl. steel saddle tanks off of one of my big trucks if that will work for you.
STK1217 is offline   Reply With Quote
