Old 04-30-2019, 09:47 AM   #1
SST159
Liked 20 Times in 16 Posts
Default Trailer Generator slide out tray
Any suggestions where I can get a generator slide out tray that will hold 200 lbs?
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 04-30-2019, 10:19 AM   #2
Keith 944
Keith 944's Avatar
Default Re: Trailer Generator slide out tray
I got the brackets at Home Depot and then put a very thick piece of wood across holds my Honda 3000 fine
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-30-2019, 11:09 AM   #3
SST159
Hey Keith,
Do the brackets slide?
what department did you find them in?
Drew Wonderly
SST 159
Old 04-30-2019, 12:10 PM   #4
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Home Depot has some heavy duty slides that are usually in the Hardware Section. Basically just heavy drawer slides. Inside of the display drawer they will have the weight rating for each one.
I think the brand is everbilt
Here are the ones I got. Mounted them on a piece of aluminum angle. For the tray use aluminum angle for the perimeter with aluminum treadplate riveted to it for the floor.
https://www.homedepot.com/p/Everbilt...ZP-W/302867528
NSSGTO is offline   Reply With Quote
Old 04-30-2019, 01:04 PM   #5
Keith 944
Keith 944's Avatar
Yes basically what he said
very heavy duty works fine. I like his idea of how to finish it mine looks factory I covered it in carpet I would take a picture of it but I left the trailer at Atco
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-30-2019, 01:09 PM   #6
Jeff Stout
Liked 708 Times in 285 Posts
Used the same brackets for a BBQ grill that stowed away in basement of motorhome. Pulled it out and cooked. Held up fine for having a regular size grill on it
Old 04-30-2019, 10:08 PM   #7
SST159
Thanks guys for the advise and ideas.
Drew Wonderly
SST 159
Old 05-02-2019, 01:32 PM   #8
mschafer
Liked 13 Times in 9 Posts
Vintage trailers sells one that is excellent,I have it in my Outlaw and two other racers have bought one after seeing mine, sells for around $200.
mschafer is offline   Reply With Quote
Old 05-06-2019, 09:53 PM   #9
cmracing
Liked 62 Times in 29 Posts
I made slide outs for both of my trailers. Bought the slides from McMaster-Carr.
cmracing is offline   Reply With Quote
