Old 03-28-2019, 03:31 PM   #1
bert powell
Liked 34 Times in 12 Posts
Default 82 MPR Camaro GT/IA 402 BBC
Price reduced!
1982 Camaro coupe/claimed as 1986 (comes with title)
Chassis built by MPR Mike Pustelney
9" Ford with Mark Williams lightweight aluminum center section
Strange axles
5.83 Pro gear ---New
15"x14" weld wheels rear---15"x3" weld wheels front
Phoenix 14.5" x 32.0" bias tires rear---Goodyear tires front
Lamb brakes front and rear---rears are dual calipers
Koni adjustable shocks front, valved at True Choice, Koni double adjustable rear
Dual Exide batterys ---New
CRC combo fuel pump and filter---BG 4 port regulator---both just sent out for service
MSD ignition---7AL2 box ---HVC 2 coil
ACD air shifter and Hurst Quarter stick-- 2 air bottles just filled
Autometer play back Monster tach
New 5 gallon fuel cell
Rossler lightweight Turbo 400 with brake
Aluminum transmission shield
ATI 8" convertor---New
Dynotech aluminum drive shaft
New engine fresh off dyno
1970 402/300---NHRA rated at 308h.p.
GM 454 case with 8 sleeves---.060 overbore
GM steel crankshaft ---reworked
BME pistons
Eagle H beam rods----------ARP 2000 bolts
Comp cams roller cam and lifters
Jesel belt drive
Super Stock shoe box style oil pan with mini sump
ATI balancer with aluminum hub
MSD crank trigger
GM 820 cyclinder head castings
Manley valves
Comp Cams 948 springs
Jesel rocker arms
Trend pushrods
Dart inlet manifold
9207 Quadrajet
Davis 3 step headers---just ceramic coated
This car has gone 9.49 @ 139.6 mph @ 3275#s
Will run GT/IA at 3250#s---GT/IA index is 10.65
Many spare parts also available.
Will sell complete for $38k or reasonable offer, or will sell engine only.
Call Vince 586-749-0200 business hours. No texts.
bert powell is offline   Reply With Quote
Search this Thread:
Advanced Search
