Liked 105 Times in 26 Posts
I’m building a street 67 Camaro with a G101 and Long pistolgrip but I’m thinking about not using the Long because I have to murder the tunnel.A friend of mine said he thought he remembered having to cut the tunnel somewhat to use a Hurst Supershifter as well.This is a Street/Strip car and has a pretty decent interior so I’m up in the air on what kind of shifter to use. Any thoughts on this would be appreciated. Thanks
Go with a Hurst completion plus and it will fit in the stock console. I also modified the mounting pad to move the shifter closer to the center of the trans as the mounting pad is quite thick.
Copy on the Competition Plus.I don’t mind cutting the floor but nobody makes any kind of boot or cover for the Long shifter that I can find or I would use it. Thank you for the input .
Liked 808 Times in 247 Posts
Absolutely use the Long shifter unless you want to kill your trans.
Liked 2,013 Times in 604 Posts
The G101 appears to be a copy of the BW super T-10. I ran those in my Camaro years ago. I did have to cut for the shifter using a v gate shifter or Super shifter but did not have to cut the side of the tunnel. I did have to cut the side of the tunnel out when I went to the 5 speed type trans. There is no type boot available to cover the shifter for a V gate type shifter. You would have to have an upholstery shop sew up a leather one with a draw string at the top.
Mike Pearson 2485 SS |
Liked 56 Times in 29 Posts
I use the Mr. Gasket Vertical Gate (later called the Hurst V Gate 2) and occasionally you find one on ebay, and also the original rubber boot made for it. You will have to cut, but not much more than for a Super Shifter. The shifter will need a little bigger hole, but the cut or bending for the rods is the same with the SS and the VG. I also custom make the mounting plate to put it where I want it, to clear my bench seat.
