Old 07-14-2018, 06:21 PM   #1
DailyDriverSst
Liked 7 Times in 6 Posts
Default Inline stop recc / release speed info
I am looking for suggestions regarding the inline stop that is easiest to control it's release speed. Having a second cylinder for SLE would be nice but not required.
I am running EFI with a 4500 throttle body, so a plate stop won't work for my application.
I know that fundamentally the two options are Dedenbear and K&R, but with my situation I need to be able to controllably load how aggressive the power goes to the tires as the stop comes off.
DailyDriverSst is offline   Reply With Quote
Old 07-15-2018, 01:26 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Inline stop recc / release speed info
The control comes from having an adjustable air-bleed fitting so you can regulate how quickly the air is reapplied to move the throttle.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 07-15-2018, 02:53 PM   #3
DailyDriverSst
Dan
Hi Dan,
Thanks for the info. Do the fittings come/ordered with the stop or sources separately?
Old 07-15-2018, 06:40 PM   #4
Keith 944
Keith 944's Avatar
Check Biondo site I’m pretty sure they’ve got most of what you would need
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-15-2018, 07:32 PM   #5
DailyDriverSst
Thanks Keith.
Old 07-16-2018, 01:13 PM   #6
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
You need this guy right here:
http://www.biondoracing.com/product/NV.html
I use this throttle stop:
http://www.biondoracing.com/product/PCTS-SH.html
I don't use a valve to control the opening speed though. I think that if your car can handle it, then fast action is most consistent.
S/ST 51
S/C 53
