Old 05-21-2018, 08:33 PM   #1
Hacksaw
Liked 315 Times in 178 Posts
Default Slick Balancing
Have an older FMC bubble balancer and having trouble, way too sensitive to work with. Just about ready to put mud in instead of gear lube. ???
Old 05-22-2018, 12:13 AM   #2
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Default Re: Slick Balancing
We've balanced a bunch of tires on a similar balancer. We found it necessary to make sure that the side of the wheel with the most offset must face DOWN. Otherwise it was so sensitive it would not work. You might try that and see if it solves your problem.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 05-22-2018, 04:46 AM   #3
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Also, place weight on inside, half way in depth of wheel. *ex* 10" wheel, glue in 5" down from bead..
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 05-22-2018, 06:19 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
another tip to experiment with;
example: say the tire needs 6 oz at the 12;00 o'clock position. put 3 oz at the 10 & 2 position.
Larry Woodfin 471W
Old 05-22-2018, 06:42 AM   #5
Bruce Schoenbaechler
Always balanced slicks with the deepest offset down. Used stick on weights, used duct tape to cover them. Never had any kind of problems.
SCHOENY
Bruce Schoenbaechler is offline   Reply With Quote
Old 05-22-2018, 09:57 AM   #6
Hacksaw
The wheels i'm working with are 15" wide rims, 4" bs. After removing the engagement lever it became possible to put the deepest offset down. This made it manageable. Thanks for the replies and advise.
