Liked 784 Times in 196 Posts
This yoke for a Dana 60 was brought to me with a pile of parts. I have not ever seen one like it but my experience with Danas is limited. If you are familiar with it, will it be durable enough for a 3000 lb car running 10.0 with a transbrake on 10.5 tires? If not, what would be an affordable (cheap) replacement that will work?
![]() Last edited by Dwight Southerland; 09-01-2019 at 07:56 PM. |
Liked 265 Times in 69 Posts
Looks like the u-joint is held in with 1/4 in bolts. Not sure if is strong enough. What size are the u-joints? You will probably need 1350 joints to be safe. Don't know about cheap.
John Dinkel 3295 STK |
Liked 129 Times in 59 Posts
I can't read the casting number in the second picture, Dwight, but if it's a Spicer yoke you should be able to identify it at the Dana-Spicer (http://www2.dana.com/expertforms/departid.aspx) website. It looks like a cast piece anyway, and I agree with John, you'd be better off using a forged yoke that utilizes u-bolts instead of capscrews and straps. The Moser catalog would be a good place to start.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 800 Times in 237 Posts
Dwight, that style yoke was used on many of the 3/4 ton Dodge trucks with the 60 series rear ends, FWIW. -Al
"That'll never work....." |
Liked 695 Times in 206 Posts
I broke one just like that 30 years ago in a 10.90 bracket car. Really fudged a lot of stuff up. Use one with U bolts. Dyno
Liked 28 Times in 15 Posts
Dana makes a yoke that uses U-bolts - looks same as my Dana 44 yoke.
