Old 02-04-2018, 11:02 PM   #1
Rory Christianson
Liked 9 Times in 6 Posts
Default Super gas hood rule
Hi
Just working on a super gas car which is getting a enderle stack injection so stacks will be sticking through the hood.
Car will have a hood just no scoop over the stacks is that fine in super gas ?
Or is there a rule stating otherwise ?
Thanks
Rory Christianson is offline   Reply With Quote
Old 02-05-2018, 01:50 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Super gas hood rule
Check with a tech. There is a reference to an 11 inch rule for hood scoops on SS and SG, but no stated exemption for stack injecters. If a carb has to be covered then injectors might also.
Dale Shearon
68 Mustang 6394
Old 02-05-2018, 09:50 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Only carbs sticking thru the hood need a flash shield to prevent fuel from siphoning out .
Stack fuel injection is ok without a scoop or flash shield ,as there is no fuel bowl or vent for fuel to siphon out of .
I would defiantly run screens in the stacks . hard enough to keep debris out of a carb let alone 8 stacks !
Old 02-05-2018, 11:29 AM   #4
Keith 944
Keith 944's Avatar
There is a 55 Chevy that runs stacks in s/g saw him at Maple grove I believe. X2 with the screen!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-05-2018, 10:56 PM   #5
Rory Christianson
Thanks guys appreciate the info
Yes I was going to run some kind of screens
Any thoughts of pros and cons to making one competitive ?
Thanks again
Old 02-06-2018, 12:28 AM   #6
Tom Goldman
Thanks again
the down side of mechanical injection is that for it to make it work consistently on a throttle stop usually requires closing down to Idle.
Some racers have had some success using a part throttle bypass off the barrel valve [similar to what a Sprint car or old Modified Stock car would have used ]. by using a controlled bypass on the barrel valve I've known a few racers who successfully got the injection to cruise on the stop at around 4000 rpm. But most guys opt for going to idle as it yields much higher MPH .
Kinsler used to offer a nice slip in domed screen that had a formed ring that secured in the stack tube. ...not sure if they still have them.
