Old 01-19-2018, 11:52 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1967 427-435HP Tripower Corvette Block & Crank
1967 427-435HP tri power 4 bolt standard bore block casting number 3904351 dated C-31-7 stamped T0501JE 7118233. Block was cleaned and magged and the cylinders are very clean with no damage. Also included is the steel 6223 cross drilled crankshaft which is standard and has been greased down. Should polish up. The parts can be shipped if you cannot pick up and any questions I can be reached at 330-770-2517.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
