Liked 20 Times in 15 Posts
For a low class stocker, T/U, is a post unit more efficient to use, less reciprocating weight? Any other advantages?
Liked 319 Times in 68 Posts
Spool is lighter,if you pay attention to the circumstances of the tires a posi doesn't help.
Lee Valentine 1661 STK |
Liked 138 Times in 51 Posts
Weight is always important, especially when you don't have much HP to get it moving. Plus there are no moving parts to break or wear out with a spool. Cheaper too!
LOCOMOTION Racing |
Spool. In addition to lighter, stronger, and cheaper, zero chance of the clutches in a limited slip unit slipping.
Liked 173 Times in 82 Posts
I've tried both, never really noticed any difference. I currently run a spool in the original 6 cylinder rear end (Dana 35), it is a little quicker than the big V8 rear end I ran originally.
Jim Mantle V/SA 6632 |
Liked 25 Times in 16 Posts
How do the aluminum spools hold up with a low HP engine? I'm thinking of using one with a 273 2bbl engine in a Dart. I'm estimating I need 225 HP to run the index.
Mopar 2 Ya! |
