Liked 100 Times in 51 Posts
I have a 582, BBC, with BB3xtra Oval port heads, 2.350 SS Manley Intake valves. The motor has about 60 runs. I have (2) valves that have tulipped. Motor runs about 7300 rpm through the traps. Motor has never been over-heated or run lean. Antone have any experience or thoughts about what may cause this???????
Thanks, Dan Foley |
Liked 362 Times in 105 Posts
With that large valve you need to go with a light weight tiatanium valve. The steel valve is hard on the springs and they tend to do what you describe in a short time.
2.200 is as large as I would ever go with steel and larger than that I go with tiatanium. I believe a Brodix rep gave me this same recommendation some years ago. Just My 2 Cents and experience. Rick Cates in TX |
I agree that titanium valves are easier on springs, but, there are too many Brodix heads with this size SS valve running w/o this happening. I've previously talked with Jeff Brotherton, from Brodix, and asked if titanium valves were worth the investment with my combination. He didn't think I would benefit from them. I am wondering if the springs were weak that it may be hard on the valves and cause them to slam into the seats too hard or too often.
Dan |
The biggest benefit with titanium valves is the maintenance factor. I have not used a SS intake valve since the early 1990's.
Titanium is so much easier on the entire valve train. Just My Experience Rick |
We agree that titanium is better but, according to the cylinder head specialists Brodix, they aren't required. Bordix is even at a loss as to what happened.The real question I had is what caused the valve to tulip?
Dan |
Liked 2,006 Times in 602 Posts
Probably just a couple of bad valves. I have had bad luck lately with Manley SS exhaust valves. I have had 2 exhaust valves drop the heads off and destroy 2 good engines in the past couple of years. The last set only had about 75 runs on then. These are small diameter valves too. I guess I will start to change the valves at 50 runs from now on. The Manley stuff does not seem to be as good as it used to be.
Mike Pearson 2485 SS |
