Old 03-29-2017, 02:33 AM   #1
Max Wedge
Thumbs down BB Mopar 440/ Max Wedge Street/Bracket or Stock Eliminator
Manley H-beam rods with ARP 2000 bolts $450 set
Manley billet I beam rods with ARP 2000 bolts $800 set
CP 1963 426 Max Wedge low compression pistons M13CP +.060 with spares, pins and rings $550 for all
CP 1964 426 Max Wedge high compression pistons M3CP +.060, with new spare, pins and rings $550 for all
440 cast iron crank, internal balanced with Mallory, cryogenic treated, standard mains and 3.757 stroke .010 rods with fresh magnafluxed and polished. $450.00
Standard coated main bearings 119M Federal Mogul off above crank, literally like new $40
.010 coated rod bearings-new in box CB527HNXD-10 $130
Fully machined and ready to wash and build 413 Industrial block 4.316 bore with fresh torque plate hone. Block was in A/SA Max Wedge car for past 6 years. No issues. 1/2 filled, bushed lifter bores, oil gallery and windage modifications, ARP main studs, coated cam bearings, decked and align honed. Run as is or take bores +.004 more for a standard bore 440. $2,200
New and used stocker Max Wedge camshafts. All are solid lifter cams, have Comp, Crane and Bullet like new condition .
$100 each for cast cams .509 and .520 lift
$525 for billet dual swap firing order shaft .509 lift
Shubeck flat solid .904 ceramic puck lifters SOLD!
Spend 1,500 get 10% off
Spend 3,500 get 20% off
Call or text (330) 418-0490 or email mwedge426@aol.com
Max Wedge is offline   Reply With Quote
Old 03-30-2017, 06:17 AM   #2
Max Wedge
Default Re: BB Mopar 440/ Max Wedge Street/Bracket or Stock Eliminat
Lifters are sold.Thanks Classracer.com!
Old 04-08-2017, 11:44 AM   #3
Max Wedge
Both sets of Manley rods are gone.
Search this Thread:
Advanced Search
