Old 03-27-2017, 04:29 PM   #1
Tom Turner
Default LT-1 Stk Elim Engine
LT-1 Stock Eliminator race engine. 92-98. Full blueprint LT-1 block, All machine work and balancing done by Action Machine. CP pistons, Total Seal rings, Manley rods, .015 stroke Nitrided crankshaft, H-bearings, ATI aluminum balancer, Comp Cams Hyd roller, short travel lifters, Haskell heads, Crane Nitrocarb rockers with Koolnuts, , Stainless (USA Made) valves, PAC springs, ultralite retainers, machined keepers. 630 intake.modified fuel rails, NHRA legal Stef's oil pan and custom pump. Everything the best, absolutely completely fresh. Engine is complete with Meziere water pump and massaged Optispark distributor, LESS throttle body, injectors and ignition coil. These engines are very durable and low maintenance, Will go 100's of runs without a problem. Go .85 under in bracket mode in good car. Cost 10K + to build. $6500 plus freight or pickup at my shop in Federal Way Wa. Tom Turner. 253 381 2066 NO TEXT! or, 888 438 1968 Russ. TEXT your little heart out.
Tom Turner is offline   Reply With Quote
Search this Thread:
Advanced Search
