Old 03-11-2017, 04:09 PM   #1
goinbroke2
Liked 405 Times in 158 Posts
Default 351w vs 351m
Looking at the guide got me thinking, a 75 or so wagon came with both and was wondering if there are any opinions from those who are familiar with them, what would be the better choice?
351w
Lighter overall, good pistons and rods available but terrible heads and intake. 1.78 / 1.46 valves and .419 lift
351m is heavier with massive long rods with no replacement rods or pistons. But, 2.05/1.65 valves with better flowing heads and intake. .409 lift
Both run the same 1.21 carb.
Not sure if the heads will overcome the extra weight.
Thought?
Old 03-11-2017, 04:57 PM   #2
Mike Graham
Liked 341 Times in 67 Posts
Default Re: 351w vs 351m
M has almost 20cc bigger head cc. some of that is recovered in the difference in piston dish. The carb will be the limiting factor. Not valve size. Plus it looks like M carries 10 more hp factor. 351w W all the way.
Mike Graham is offline   Reply With Quote
Old 03-11-2017, 07:17 PM   #3
Rory McNeil
I have not checked the Guide for a 75 Ford, but I seem to think that the 351Ws had 1.84 & 1.54" valves, up until about 77 or 78. Also, with a 2 barrel carb, the 351Ms larger valves won`t have much benefit. Depending on what chassis you are looking at, the 351W engines came in more models, the 351M was mainly full sized cars, and PU trucks and vans.
With the 74 Ford 460 smogger engine rather popular in S/Stock, one has to wonder how it would fare in Stock. All pretty heavy cars, but a 460 cube engine at 300 HP.....
NHRA 6390 STK
M/S 85 Mustang
Old 03-12-2017, 11:31 PM   #4
rawhide
Liked 7 Times in 5 Posts
I believe that the valve size was reduced in 1975 for the 351W.
Roland
rawhide is offline   Reply With Quote
Old 03-12-2017, 11:41 PM   #5
goinbroke2
Thanks for the replies guys.
Yes '75 was the first year of small valves. Just happen to know where a 77 Torino with a 351m is and it got me thinking. Both have the 1.21 carb, I just thought maybe the bigger valves and ports would be better. My biggest concern with the m would be the crappy oiling system and having to run stock cast Pistons.
As far as the factor I thought I saw both at 230 and the 400 at 240.
Anyway, after reading the thread about reducing hp 20 percent it sent me looking through the guide and kijiji! Lol! A 351 at 184hp might actually be able to hit the index with enough work, 230? Not a chance.
