Old 01-24-2017, 11:32 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default "Super 10" Super stock heads & intake & cam & carb
Super Stock racers,
The idea is being considered to change engine combinations with my Super 10. The heads are Gary Hettler design with about 15 runs since new. All parts are new, valves, springs, retainers, seals, locks. The casting number is 041, this is the 327 or 350 head with 1.94 x 1.50 valves. They are fully worked, latest design, Hettler heads.
The heads are fitted with T & D shaft rockers but I may retain those, depends on a racers needs.
In addition, the intake is a Victor E, also fully worked and matched to the heads by Hettler.
*Two Heads complete, race-ready = $6,100.00
*One Victor E for above heads = $400.00
*T & D set with 1.7 rockers = $900.00
*Comp Cams specific grind per Hettler = $300.00 [cam is BBC journals]
*Quick Fuel carb, NHRA replacement for 300/327, tested and corrected on BLP flow bench.= $600.00
Contact me if interested. Thanks, Larry Woodfin
Larry Woodfin 471W
Old 01-24-2017, 01:49 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: "Super 10" Super stock heads & intake & cam & carb
"The casting number is 041, this is the 327 or 350 head with 1.94 x 1.50 valves. They are fully worked, latest design, Hettler heads."
Hi,
My belief is that the 327 and 350 combo with these heads have different combustion chamber volumes....57.5 vs 61.2
Just sayin'
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-24-2017, 03:06 PM   #3
Dragsinger
Bob,
you may be correct, I will double check with Hettler to be sure. He specifically designed them for the 327/300 package
Larry Woodfin 471W
Old 01-24-2017, 09:32 PM   #4
Woodfin
Liked 288 Times in 109 Posts
A double check with Hettler, chambers are 57.5 cc
Search this Thread:
Advanced Search
